Solved Issues with System Updates
Solved
This should now resolved and able to update again from this version.
hello, unfortunately I keep getting the same message:
Oooops, there was a problem with the update​
Unfortunately it's not possible at the moment to update your system. Please contact Innuos and mention the following message:
An error occurred while attempting to download
From v1.4.9? Did you try rebooting the system first?
If with "rebooting" you mean turning the Zen Mini Mk3 off and then on again, yes I have rebooted it. I had successfully updated from 1.4.3 to 1.4.5 to 1.4.9 but then it got stuck.
The issue is not related to the outage we had last week, we have tested 1.4.9 updates and they're working, so there is a deeper issue with your particular system. If you already have an existing support ticket about this with us, then we need to continue with that.
thank you. I guess this means I won't be able to escape the 70 EUR fee that comes with such intervention.
