Solved Qobuz playback issue
Solved
DanCollier
361
37
218
43
30
Oxford
We’ve received a few reports from users experiencing similar issues with Qobuz, where certain tracks fail to play. The affected tracks seem to be random, but once identified, they tend to consistently fail on those systems, even though they play without issue via the Qobuz app on a phone or tablet.
This is not isolated to our platform, as other brands such as Naim, Roon, Wiim and more have all reported similar behaviour on their own support threads. This will be related to ongoing infrastructure changes on Qobuz’s side.
We’re looking into this.
Upvote 0
A quick update on this.
We have identified the source of the playback errors: it is a caching anomaly with our CDN provider.
In practice, some distribution servers are hosting a corrupted or incomplete file. Since each audio quality corresponds to a separate recording, switching quality often allows you to fall back on a healthy file and work around the issue.
Our teams are currently listing the affected tracks and carrying out a gradual cache purge. The situation should be resolved very shortly.
Thank you again for your patience and understanding.
The Qobuz Team
We’ll share a further update as soon as we hear more.
Reactions: Malc.
Hi I have the same problem as described here with playback of Qobuz (random) tracks.
I have noticed one thing that no one else have mentioned: on my InnuOS devices (Pulsar & Statement NG) the problem only occurs on High-Res tracks !
It has persisted for weeks now quite annoying
For some tracks the problem has occurred an then later disappeared, for other it has persisted (try: Veronika Rud, album: Nothing, track: sang om håb)
Your track in my system is reproduced without problem
I took up the issue with Qobuz, they just reiterated the information Dan has provided so far. They did suggest switching quality may yield a solution and not surprisingly played down the extent of the problem.
Hi Luigi61
I can not explain why but I can still not play the track “Sang om haab”
Maybe the cause is not the same ?
I have experienced different behaviors from different tracks (HI-RES)
Hi Luigi61
This morning I cannot paly it as well. This is a mistery!
These days, I realize just how vulnerable streaming music is.
Fortunately, I still have all my CDs and vinyl records!
Hi Luigi and all
Today I took contact to Qobuz explaining my experiences with failing tracks I am now waiting until Costumer Support mails me, doing this I made a playlist with 9 random HD Tracks that would not play but skip instead. All this was this morning.
By now at evening all those 9 tracks has come back to be playable again.
I hope this means Qobuz has put some resources in getting back to deliver HD tracks reasonable reliable again.
Hope this means this tread can come to an end soon
Hi Luigi and all
I can confirm that this evening, at least in the last 6 hours, I didn’t have any skipping track.
Finally I can relax listening to my system :)
Does tidal have any issues like this as I’m also constantly having to reapply albums in Qobuz that have changed somehow. Main issue here is that you don’t always realise when playing playlists and playing tracks randomly
I have the same issue on Qobuz with the song 'The Shadow Of Your Smile' on the Stacey Kent album 'A Time For Love'. The same song is on the album 'A Little Time For Love' and that track plays fine.
For me, “Stepping Out: The very best of Joe Jackson” skips from track 2 to 3 half way through the song “Sunday Papers” on an Innuos Zen, firmware version 3.4.2, streaming with the SenseUPNP app from Qobuz. And again on track 6, "Fools in Love".
Streaming to my Naim NSS333 using the Naim app, playing the same tracks from Qobuz works fine.
I played both tracks from Qobuz with no problems, Innuos Statement/Nagra DAC, via Sense, latest firmware version. System set standalone, UPNP off.
I have been experiencing a number of issues recently with Qobuz, seems a lot better over last few days, not sure if 100% yet though.
I have experimented with putting a USB DAC on my Zen Mk3. The Joe Jackson album first three tracks played fine from Qobuz to my Zen through the USB DAC without problem. Switching back to the ethernet player output from the Zen to my Naim NSS333, I played Joe Jackson on Qobuz from track 4. At track 5, half of the piece is played and then the playback skips to track 6. I think the problem I am experiencing could be with the SenseUPNP feature.
I played the first three tracks from Qobuz through Naim streamer (without the Innuos box involved in the playback route) this morning. No problems with that. On Qobuz there is one version of that album, flac 16/44.1, so there is no possibility of different files being played.
This morning after reading your posts I tried the Stacey Kent album again. Al tracks played normally on Qobuz. So it probably is an instability on the Qobuz side of thing, not a Sense issue. I had the same problems some weeks ago with a dEUS album, one track not playing. A few day later the album played without problems.
That suggests no problem with Qobuz, also from what you are reporting above Innuos Sense appears to be working ok in non UPNP mode ? I found the same, no problems playing the album but I'm not using UPNP
It is only the combination of playback from Qobuz and use of the SenseUPNP feature that is a problem for me. This album and others playback fine when a USB DAC is used or when I stream using the Naim/Qobuz integration.
For me the problem is not over, yesterday I would play this track that failed:
The problem seems to come and go.
I am playing on InnuOS Statement NG with Sence 3.4.2
Launched a Qobuz playlist a couple of days ago and a few songs into playback it started to act up. I heard silence and when I glanced at the progress bar for playback, the bar would move for a few seconds, stop, and reset to the beginning of the song and start moving again. It would just stay there repeating the same routine but with no sound. I could select the next song and it would either play the next song or go into the same routine with another song. The only thing that finally solved it was me going into advanced settings and clearing the playback buffer. I’ve had this problem for months now on both of my systems using two different Pulse Minis so not a specific system issue. Today I noticed a new problem with the Qobuz integration in Sense. If I go to an Artist and scroll down to the list of that artist’s albums in Qobuz, a weird thing happens. If that artist has more albums than the initial screen shows and I click on “show more”, within a few seconds the additional albums just disappear! Going back and clicking the “show more” button does the same thing over and over. This Qobuz integration is getting pretty unusable. This happens on my iPhone 17 Air with the latest IOS, using the latest Sense version. It’s actually worse on my iPad Pro where the list of albums eventually disappears altogether.
