Calling Sense 3 Beta Testers, who's in?
For those encountering the beta Radio issue, please could you test something for us.
In Sense app SETTINGS, please disable your UPNP function completely, then reboot the system. After that, please try again to use the new radio/podcast services.
Hi Stephen, just done as you suggested and unfortunately for me at least no change and I'm still getting the spinning wheel for both Podcast and Radio
for me, where it works perfectly since the first BETA version, the UPNP function has always been disabled.
I already had UPNP disabled and am also getting the spinning wheel. In addition, despite a remote session which proved to be unsuccessful and a subsequent promise of a hot fix to address the issue, I continue to experience resetting of the volume control to 50 from the preferred 100 whenever restarting Sense and random drops in volume to 50 when playing music.
I tried it as you suggested but it still doesn’t work unfortunately.
it also does not help for me... Still the spinning wheel
I’m glad I could help narrow down the issue. I can confirm that Radio & Podcasts work fine. There’s an amazing selection of stations! The icons of the stations are displayed in the Web browser and the public app, but not in the current 1.5.0. (101) Beta version. However, the developers are aware of this and it’s being fixed soon. So, I guess we’re getting closer to an official release of Sense 3.1 :)
Thanks to some direct assistance from @mountainview we believe we have found the source of the issue affecting some users, so is now on the development sprint for the next beta increment.
Edit: typo
I get a notification that 3.1.0-8 is available but when I click on that I get 3.1.0-7 and the messagetaht I am up to date...
Are you referring to Radio page issue, while the white page issue is in same way correlated to this or we still need to wait for a fix in that case?
Yes, I was referring to the Radio and Podcasts overhaul that will be introduced in 3.1. For several testers, the platform was not working at all which was surprising as it worked fine during all our internal testing, so there was more work to be done!
Reactions: luca.pelliccioli
Just a potential heads-up for the users who had earlier beta versions of 3.1; you might find that if you saved any podcasts as favourites during the beta period, you may find now that after the official update these saved presets on the widget no longer work - you simply need to unfavourite then re-favourite these podcasts to resolve.
The problem does not seem to apply to Radio station presets, only to Podcast presets.
