Zenith mk3 plays music immediately at switch on?
frank7036
Jun 7, 2024
176
South Australia
Hi All,
When I stop playing a track (II) and then use the off
/shut down button under the system menu all good, Zenith shuts down correctly.
Power off the stereo.
When I come back the next day and power up the stereo again, as soon as the Zenith mk3 is powered up and BEFORE I start Sense app, the same track as I was previously listening to begins playing through the stereo. Is this correct??
It seems that the last song playing is in memory however I would have thought that “shutting down the unit” would clear all memory?
If I’m doing something incorrect I’d appreciate a heads up.
Regards. Frank
Reactions: gilbs2709
This is the correct page, so now all you need to do is change this line:
And try changing it one of the other options - I would suggest you select from the 'Pause at power off / remain paused at power on' option
Hi Stephen,
Thank you, can you elaborate as to why choose that option over stop at power off / remain stopped at power on?
Thank you in advance
Hi Stephen,
I'd need to test to make sure, but would anticipate fully 'stopping' will clear any current queues. You are quite welcome to try remaining stopped however, and test whichever one solves the problem for you.
Reactions: frank7036
