Solved Tidal MAX - Incorrect 24/96 now playing resolution
Solved
Stephen Healy
1,112
82
637
113
Haywards Heath, UK
There is currently a known issue when playing Tidal MAX tracks that the incorrect resolution is being stated. This applies only to Tidal tracks that have not been saved into the library, so would only happen when browsing through the Tidal categories or search function and playing music outside of your saved library. Tidal MAX music found this way will invariably state a resolution of 24/96 regardless of the actual resolution of the file.
The fix will be addressed in the next Sense update.
Reactions: justaute
Upvote 1
