Solved 'Add to Queue' on empty queue begins playback
Solved
Stephen Healy
1,258
91
694
113
Haywards Heath, UK
After 3.4 we are aware of an issue if 'Add to Queue' is used on an album with 2 or more tracks when the current queue is empty, then playback will immediately begin from track 2. The cause is known and will be resolved in future update.
The workaround for now would be to avoid adding music into an empty queue, and if building a new queue from the beginning then start by playing the starting content, then use Add to Queue after that.
Upvote 0
Is that the same: if I would start a qobuz playlist the 1st track is not playable, I can start the playlist only from track 2 ???
Despite having Sense 3.4.1 loaded via my browser, it continues to immediately begin playing songs when added to an empty queue. This just occurred on the very first track that I added to the queue, so it doesn't appear to only happen to the second track added.
Hi.
I'm unable to replicate this, the fix works fine on my two systems regardless of what device I use Sense on.
Go to advanced settings, and clear your queue cache, then retest.
Hi.
Ok, Dan, I just went to the Advanced Settings and cleared the queue cache. I opened an album and began adding the tracks to the queue one-by-one. The first track loaded into the queue as expected; the second track loaded then started playing immediately. In my experience, the unintended automatic playing of tracks being loaded into the queue is not limited to the second track loaded. I've had first loaded tracks launch on occasion, and later tracks on other occasions. I haven't been able to identify an absolute pattern to this behavior, i.e., whether it typically happens to the first, second, or ?? track load. On the other hand, there have been times when I loaded tracks into the queue and none of them launched inadvertently. Go figure...
