Hi there,
I've recently purchased a ZENith MK3 4TB.
I'm coming from roon and read about the better sounding sense app but before I can do a longterm comparison in my setup, I need to get it running probably.
I've set up a library in sense with both local files and streaming services and also as roon core, so I can switch. I hoped for faster switching between the two but I can except the minute.
What I noticed from the beginning is that there are gapless playback problems that I don't have playing the same album with roon or the native app of my streamer (I'm not using the ZENith as a streamer). I found that there is the possibility to change settings within the logitech media server but I only found that the crossfade can be enabled and modified. Is that something you have adjusted?
When I use sense, sometimes there is no coverartwork shown on my streamer display. How can I change this for good?
Never had this issue with my roon nucleus and also not when I'm using roon on the ZENith.
Is there a way I can merge local stored albums if I have the same album in Qobuz or Tidal (show as one)- like roon does?
I'm missing "last played" albums on the home screen. By far the most important widget.
I found a plugin in the logitech media server settings called band's campout for bandcamp.com but it doesn't seem to work in the sense app?
Thanks in advance for your help
