How to setup Fix/Static IP address for LAN and Ethernet port on PulseMini? How to configure two network interface on two IP subnet/segments or VLANs?
AJ506
Taipei, Taiwan
I do not know how to setup static IP address for PulseMini and If try to connect to two Segments or VLANs that the network will become loop and one port will block.
I have other stream player have no this issue.
Lee
I have couple of PCs/smart mobiles as well as iPad and couple of stream play systems in my environment and random of wifi users, for security and without impact each other that all internal user and system are fixed IP under four VLANs/Segments by 100G/10Gbps backbone switches, all streaming player have two LAN ports, one to link to NAS system (NAS also have two LAN ports at least) for play music files, one for control and management only (no interference with each other), I can setup fix IP based on MAC in switch port (not on PulseMini like you reply) but the real issue is two LAN interface (PulseMini) only support one port active, if connect two port to same VLAN (same switch or diff-switch) or different VLAN that the network will loop with STP blocking...either L2/L3
