@frank7036 This will require a Kernal update. This is in fact coming in an upcoming update, however we can resolve this ahead of that for you. Please send me a message with your systems serial number and the firmware version you're running.
Hi Dan,@frank7036 This will require a Kernal update. This is in fact coming in an upcoming update, however we can resolve this ahead of that for you. Please send me a message with your systems serial number and the firmware version you're running.
Hi Stephen,In terms of hierarchy, it is not quite as linear as that; the process is essentially always USB -> I2S -> D/A conversion, the question is whether more of that process happens on the source end, or happens on the DAC end. Which is better? It completely depends on the source and DAC components involved, so we cannot categorically rank one connection type over another because it very much is system dependant. We are offering our own very high-quality take on I2S transmission, but this might not strictly be better if you have a DAC with an already excellent USB input stage.
The two modules are relatively equal from our point of view, so if unsure which way to go then it can be worth contacting the DAC manufacturer themselves to see if they have a strong preference concerning their own devices.
Any thoughts @Stephen Healy ? @DanCollier suggested I post here on the Community board.Hi Stephen,
Let’s forget the DAC end. To many variables there. Would having the usb signal processed through PhoenixUSB lite (or the standalone PhoenixUSB ) before going to the i2s module make any difference to the quality of the output of the i2s module?
