BIOS Update for ZENmini Mk3 with serials starting with 20
NVitorino
73
6
71
All ZENmini Mk3 units with a serial number starting with 20 will need a firmware update for the mainboard (BIOS) in order to prevent future issues.
Prerequisites​
This update applies only to ZENmini Mk3 music servers with a serial number starting with 20. Other ZENmini Mk3 do no require the update.
This update should be applied only to a system that is working normally. This BIOS update will not resolve issues.
You will need:
  1. Monitor/TV with HDMI input
  2. USB Keyboard
  3. Free USB stick with at least 1GB
How to Update​
You can download the full instructions for the update here: BIOS Update manual
The ISO image with the update can be downloaded here: BIOS Update Image
Need Help?​
If you need help applying this firmware update, please contact your Innuos dealer for help. Any issues while updating please contact Innuos Support and we'll be happy to help.
Hi
My ZenMini SN starts with 21000000. I met issues with playlists or album which could block on one track with the timer going to 8/9s and restarting at 0s. Do I have to update the Bios ?
Thanks for your support
Hi
Loc, I have the same issue with certain hi def albums. I updated my bios several months ago. The issue seems to have started after a recent system update on my Zen mk3. I logged a support email today, perhaps you should do also.
Thanks Trev007 for your message. I do also believe that this issue arrived with one of the updates. I am already in relation with Daniel form Innuos support. I have sent several Logs to help. They are working on.
Any further on with the issue? I haven't heard anything since my automated reply
The ZenMini worked 2 days without any issues. But they came back yesterdays. I donwload 2 logs that I send to the support.
Sometime I can skip to another track sometimes I have to close and restart the apps. It takes more than 1 minute grrrr.
