Squeezebox Radio
trev007
6
0
Northern Ireland
Since a recent update I now find that when I listen to music on my main system via my zen mk3, the same music starts to play on one of my two squeezebox radios which use the zen as a server. I have not created a group with the radios, and this never occurred in the past. Any suggestions? Also, I now find when I turn on my amp to listen to my zen, it is invariably already playing a radio station that I turned into on one of my radios. As I say, I have not created a group with my zen and radios so I am at a loss as to why this is happening
My speculation would be that, for whatever reason, the system is switching to one of these radios as the 'next available' output if there is a loss in connection to the DAC. However, you should still be manually having to press 'play' for music to actually start coming out of one of these zones as I do not believe we have a queue transfer function across Squeeze zones. A copy of the logs sent to our support may help so we can have a look at what is going on with the player behaviour.
