Solved Sense 3 - Software Volume Control not working with some DACs
Solved
NVitorino
71
6
70
We have reports from several users that the software volume control is fixed at 100% with some DACs. We are currently evaluating the situation and will report back a solution soon.
Thank you for your patience.
Upvote 0
The issue is now confirmed. This affects only some DACs. Anyway, the team has now found a solution and this issue will be resolved in version 3.0.1.
Reactions: Toneranger
Just to add an option:
For me it would be nice to add an option to the settings to grey out better let the volume slider vanish, as i and maybe many user dont use it, just to prevent that you artificially adjust it… would be great as other manufacturers have this option, thx in advance
