Default player?
guardajoias
Jul 18, 2024
164
Lisbon
I cannot discern a consistent policy for Sense to select a player. It often, but not always seems to go the last player used. This is further complicated because in one of my settings, the DAC (in the Devialet Expert Pro) is not always on. When I turn the Devialet back on, Innuos does not automatically go back to that although this would be my default player. So I always need to check which player is selected and if I forget I get surprises :)
Would it be possible to define a default player to be used if available and not modified?
Thanks
Reactions: simon
Yes, i do see the benefit of a set default for the output to switch to when it is redetected/back online. One for the feedback zone! (which, at some stage, i would like to migrate/port into this forum so we can have it all on one site).
