For some time I have thought that I was not hearing the same levels out of my left speaker as my right. I always figured it is either my room or my old ears. I am auditioning some new, more sensitive speakers that made it more apparent, and so I decided to do some testing. Using an iPhone dB meter and a 1 KHz test tone, I determined that the left channel is down by about 3 dB. First I swapped out interconnect cables and switched sides, etc. to see if it was a cable issue. It was not.
I figured it was my preamp which is a bit older, so I started there. I rigged up a dummy RCA cable and connected it to my Fluke meter to see how the output voltage varied by channel when playing the test tone, and it did, with the left channel consistently a lower value. I went up the chain and tested the DAC output, same issue. Aha, it must be the DAC, but I tested both balanced and RCA outputs, which are discrete on this DAC, and the issue was the same with both. There are trim pots on the DAC, so it could be adjusted, but since it is an issue with both balanced and unbalanced, the issue would be upstream from the the outputs, or both outputs are out of adjustment, which seems unlikely.
So I thought it might be the streamer, and just to be sure I swapped the USB cable, no difference there. It could still be the DAC, but it could be the streamer, and I am unsure how to confirm that one way or the other. All software on the unit is up to date. Any thoughts?
