I use my Mini 3 as a upnp server (ethernet cable) directly attached to my Naim Atom with the Naim app is used as the player.
I use the Naim app as the controller for practical purposes as I have other inputs including TV/BR input to the Naim via hdmi & therefore it’s the most flexible way to quickly switch between sources
My Question is do you think that the LPSU would offer me any possible improvement in sound quality as the Mini is only being used as a server & library manager
I am also considering whether to return it for an upgrade to “S” spec … do you consider that would offer any benefit in terms of sound quality
It’s a 4TB HDD unit and around 54% full now … I have 2 separate 4TB USB HDD drives I back up to - one permanently plugged in as the other I plug in every 2 or 3 months as a fall back - this is then unplugged & kept elsewhere in the house … I’m wondering whether a move to a permanent NAS drive for backup would be better … and possibly use the a NAS for additional library space maybe archiving some of the music from the Zen that is rarely listened to
All thoughts gratefully received
J
J
