Stuttering at beginning of songs
mashif
4
2
Tennessee, USA
My Pulse is connected to a Schiit BitFrost 2/64. The beginning of songs often stutter before playing normally. If I restart the song it plays normally. This happens with both albums and playlists. I've tried adjusting the delay after resolution changes but it doesn't help. It happens whether I use the Pulse or Quboz Connect to play.
I have both coax and USB connected with high quality cables but it happens with both. I have no way to determine whether it's the Pulse, Quboz, or BitFrost causing this. I'm just looking for ideas.
It seems worse since V.3 was released.
Can you remove the iFi and retest please in case thats to blame. I suspect not, but always worth a try.
Is your system on 3.3.1?
As Stephen mentions, please reboot your router and Pulse, then retest. If it persists, email support and send over your system logs.
This would initially sound a bit more like a network issue - how is the PULSE connected to the network? Does it have a cable going directly back to the main router itself?
Is Qobuz the only source of music you play through the PULSE, or do you have any local files on USB/NAS or use Internet Radio for example to compare against?
If rebooting of the router and of the Innuos does not seem to help stabilise the issue, then please submit a ticket via the Sense app that outlines the issue and we can take a closer look via remote session in case there are some DNS issues.
The Pulse is directly connected to my Modem/Router. I haven't noticed it on radio. I only occasionally use the USB input for a single song.
My Internet is Fiber 300m up and down into an ATT supplied modem/router. A 30ft Ethernet cable goes to the Pulse with an iFi LAN Silencer at the Pulse end.
Update:
I replaced my Schiit BitFrost with a Bryston BDA3. The slight stutter using Quboz Connect still happens but not with Sense. So the question is whether Quboz Connect interfaces properly with my Pulse. Hopefully updates to both programs will address this.
