Tidal Connect
DomTomLondon
United Kingdom
Hello. I’m running the latest Sense update 3.0.3 and I’m having issues when I use Tidal Connect. Innuos will play one or two songs in a Tidal playlist, then stop.
Has anyone run into a similar problem?
This is only a Connect issue. If I use Tidal within Sense it’s fine. Unfortunately the Daily Discovery playlists are not included in Sense.
(I’m using iOS18 on an iPhone, but this also happened when I was on iOS17.)
