Hello all, this is a general survey question, for those that have a DAC with a built in volume control. Hopefully this is not to confusing
Is the Innuos Sense application volume control independent of, or intended to be ganged to the Dac volume control via USB? meaning does the Innuos Sense volume setting adjust the volume level of your Dac volume control? Or are the two volume controls in series and fully independent of each other?
I am currently running my Zen mk3 with Phoenix USB into my Dac and using the Dac volume control to adjust the volume level of my system. My Dac is connected directly to my power amp(s). I leave the Sense volume at 100% and the dac volume is adjusted independently. This works great and i do not want it to change.
However if the Zen reboots or the USB physical connection is interrupted and re-established the Dac upon reconnection automatically goes to full volume. This is undesired behavior especially if not caught in time. With a windows PC connected to the Dac directly i do not get this Dac behavior when the USB is disconnected and reconnected. It only happens with the Innuos streamer system. So i am leaning towards the windows PC communicating USB volume settings while the Innuos does not and the Dac has a USB connection reset issue when USB volume settings are not coummicated.
Is the Dac doing this on its own without instructions from Sense? or is the Zen communicating my 100% Sense volume setting to the Dac at startup only?
At no time does the Sense volume setting affect the DAC volume setting so i am curious about cause and effect behaviors. I am in communication with the Dac manufacture and all is good there, very open dialog. I am just trying to understand what Sense is and is not expected to be doing.
Thanks for your time!
Audiogal
Audiogal
