Bbc radio stations help needed
Phill r
Member
Oct 9, 2024
49
Norwich uk
I’m running sense 3.1.1 and I can’t get bbc radio stations to work? No sound
Also the radio paradise streams just repeat the intro over and over?
Is there a problem with v.tuner?
Hi Stephen, I don’t know as bought it used so updated it when I got it. So there maybe a chance these still exist then?? If so I’ll inform the chap who bought it from me. Let me know how these maybe disabled and I’ll pass on.
Thank you
You can follow this guide on how to view all the active plugins:
If you could share a screenshot that shows all the plugins that are active with the blue checkboxes beside them then I can take a look and see which ones are 'extra' from the standard factory defaults. I do suspect there is something there that is interfering.
So did a factory reset and re installed the app and bbc still won’t work. The content at the bottom goes up to 10 secs then back to zero with no sound.@Stephen Healy?
Back to Roon then I guess for bbc radio
Out of curiosity, did you have access to the BBC Sounds platform and stations back when it was on 2.4? Because that would have needed plugins for that functionality
Thank you
Thank you
