Asset UPnP on ZEN Mk3 : Upstream Art
JB74
UK
Hi - my first post since getting my rather lovely ZEN Mk3 - looking forward to many happy hours of listening.
My primary use is using the UPnP server feeding a separate streamer/DAC combo.
I have got nearly everything set up as I like it on Asset, but one small issue remains. In order to customise the shown Artwork ("upstream"), I need to create and/or access a folder in which to put the artwork for artists, composers or folders. All the help I can find online only relates to Asset UPnP running on Linux/Synology/Windows etc, where you can access the file structure. On the Innuos I cannot access or change the file structure - at least not to my knowledge. Any ideas? Is it as simple as creating the right name of folder within (say) the Music folder that is accessible externally?
Thanks in advance.
JB
I tried creating a folder called AssetUserUpstreamImages, (which seems to be the folder title used in other Linux implementations), and loaded a few test images - but no joy. Do you know what the title of the folder is supposed to be?
I have indeed, however on re-looking again today, I can see quite a lot of options that are in different places than I was used to with Asset on another OS platform. Let me wade through them and I’ll report back! Thanks!
