ZenMini Mk III for Qobuz Connect?
Joseph
TAIWAN
I used to use ZenMini Mk III as roon core, just want to know whether it can support Qobuz Connect now? I couldn't find my device on Qobuz.
Should I need to update the firmware or to do some other steps? thanks.
If your system isnt already, I suggest you update it to 3.3.7.
It does indeed support Qobuz Connect, however not when you're running it as a Roon Core as most features from Sense are disabled. If you want to use Qobuz Connect, you'll need to switch the system mode to Sense standalone mode.
