Hi
@Toneranger,
Your question raises a good topic/feature that is worth expanding on a little.
Firstly, whilst the convenience is undeniable we are generally not in favour of WiFi when it comes to ultimate performance. The purpose of a WiFi antenna is to absorb as much high-frequency RF as possible, which is rather counter-intuitive considering all the lengths we go to with shielded cables and so on. Some things can be done to help mitigate this issue, but we generally prefer treating the network that comes in from cable as you get much more speed and reliability. So, simply switching from WiFi to Ethernet may be a small upgrade in of itself.
The Streamer port on our devices is not only useful/convenient to add a secondary streamer like you have done, but it also isolates that streamer away from shared network traffic (and noise) that would otherwise come in from a busier and noisier switch or router. Although its only the STATEMENT that has Ethernet reclocking built in, the majority of our devices have noise-isolation transformers on the LAN port, of which itself is placed on a low-noise mainboard and often powered by an LPSU. Point being, the Streamer port does function as a pretty decent-performing 2-port switch.
Quite a few customers use our devices strictly as servers only, and not as streamers/players, so the Streamer port was provided to give a good connection method for the Streamer to be connected to the network directly through the server itself.
