I have some practical questions about how to migrate from Pulsar to Zen/Zenith NG.
With the Pulsar, the favorites and playlists are stored in the pulsar, but my music files are stored in a nas. How would I migrate all that to a Zen/Zenith NG?
(1) If I use make a backup on the pulsar, will the backup contain only the favorites and playlists, or will it include the music files as well? (The answer to this will determine the size of usb/nas drive I need to store the backup.) And then, when I restore the backup onto the NG, will the music files be copied into the storage on the NG?
(2) If I use the import tool, it should be easy to transfer the music files directly from my nas to the NG. How do I get the favorites and playlists off the Pulsar?
Basically, I would like the music files to be copied from the nas onto the NG, and the favorites and playlists transferred to the NG. But after the transfer, the favorites should be referring to the copies of music files on the NG, not those on the nas. Then I can unplug the nas. Is that possible?
BTW, has anybody traded up your Pulsar for a Zen/Zenith NG? How much better is the NG?
