Sense 3.4, a couple of bugs
mpino61
6
Venice IT
I would like to report a couple of bugs on new Sense 3.4 running in English on my Zenith MK3 1TB
1)when it's playing a track from the local drive , it doesn't allow me to add it to a personal playlist that it available when it's playing tracks from Qobuz
2)when I scroll new albums from the iOS 26.2 app ver 1.7.2 and then I choose an album to view it's tracks, when I go back it goes to the beginning of the list instead to remaining at the point I reached when I closed that album .
Did anyone else observe these problems?
Can we import a Qobuz playlist into Sense so that it becomes a Sense playlist? In the way we could extend the playlist or remove tracks that no longer exist or that we are not keen on. (I haven't tried this so please pardon my ignorance)
In essence, yes.
Go to the Playlist in Sense that has come in from Qobuz.
Press Play on the whole playlist so that all the tracks go into the Queue.
Then open up the Now Playing bar, go to the Queue, and in the top right corner under further options you will have an 'Add To Playlist' option. This will let you place all of these Qobuz songs from the playlist into a new 'Sense' one. Done!
1. If I've understood what you're trying to explain correctly, it sounds as though you're attempting to add a Local track to a Qobuz playlist. A streaming service playlist can only contain tracks from that streaming service. A Sense Playlist can contain tracks from all sources. Quick, easy way to spot what type of playlist it is, is to simply check if theres an icon in the bottom right corner of the playlist. No icon means its a Sense playlist.
See here regarding playlists - https://innuos.com/kb/sense-3-0-playlist-management/
2. I've tested this on my PC and on a Samsung s24+ and Pixel 10 PRO and it performs as intended. I will mention this to the team as I cannot replicate it.
Hello Dan.
For problem #1 you are right, it's a playlist that I created on Qobuz and then imported into Sense, so the Q is there: thanks for clarifying how the sw works.
For problem #2 you need to try with an iPhone, it was not present before last update, so thanks for taking care.
Kind regards, Pino.
Problem #2 also appears on my iPhone (16 pro) and my iPad.
Kind regards, Gotz
Reactions: mpino61
In essence, yes.
Reactions: malfordlad
