Sense 3.2 no longer syncing with Squeeze-lx
rarebot6
13
2
10
UK
Before Sense 3.2 I used to listen to music stored on my Zenith mk 3 via network streaming to my Windows laptop running Squeeze-lx (as per Stephen Healy's suggestion). However, since the 3.2 updates Sense and Squeeze-lx refuse to remain synced. The first track of an album plays fine and displays correctly on both GUIs, but after that it all goes awry. Sense usually gets stuck repeating the first track (sometimes the second) while Squeexe-lx plays the second track ok but then stops and often inserts a random track from another album that was in the queue 2 weeks ago! Clearing the queue is only a temporary solution. Can anyone suggest a permanent solution? Thanks.
It may sound basic, but have you rebooted the ZENith again and made sure Squeeze-LX is up to date?
Yes, I'm running Sense 3.2.2 and LMS Squeeze-lx 2.12.4 with 'syncronize' players applied. Still no good, except they fell apart after 3 tracks on an album I just tried playing. It's very odd if no one else has reported a problem.
I did try to replicate this over the last few days with a grouped ZENmini and SqueezeLX on my PC, but seemed to stay in sync for quite awhile. Can I check thats the Innuos NOT exhibit this behaviour when just playing independently and is not grouped, or does it have queueing issues then as well?
Thanks for persevering with this issue. I've just played a complete album with Innuos running independantly. It all worked fine - no queue problems at all.
