Running Two Innuos streamers off same sense app?
StewB
10
UK
Can I run two streamers from the same sense app? Ie a Zenith and a Zen Mini? I assume the network would assign them different IP address so when installing the second new addition streamer does the sense app find it and then allow me to configure it and restore my library of music from a back up of the first streamer?
Yes you can, its very simple. Just set the main sever in Innuos standalone mode, and put the other system in endpoint mode.
You can read about this via our support section, where many helpful articles on using the Sense app can be found. - https://innuos.com/kb/multiroom-audio/
If you have any issues or questions, let me know :)
Dan, I have currently shut off my Zen mini while I set up the Zenith Mk3, I have connected both my tidal and quobuz accounts. .Tidal finished but quobuz is still saying syncing after two hours. I do have the latest backup from the Zen Mini to install for my ripped cds but cannot stop the sync in quobuz. What do I do? Also finder on my Mac mini will not connect to the zenith, it shows on the network but fails to connect. When I go to connect option it asks for user and password. I believe I put in guest not registered user but ir will not let me use guest? Again what do I do? What is the password? Is it innuos?
