Pulsar not playing
pogle
Uk
Hi, I have a Pulsar and I'm having issues with playing music after having a break. So I will put the DAC, a Chord TT2, into standby then when I go back to listening the music seems really low resolution (this has happened multiple times) or today it wouldn't play anything, on sense the track would count up to 7 seconds and then restart. This seems to have gotten worse since going to innuOS 3.4.2, I'm guessing USB connectivity is now not working as well as it used to, a step backwards!
Other Issues;
New music isn't automatically picked up, re-scan required,
If you go into an an album and press play the result is inconsistent, sometimes it will play the album, other times it will just play the first track.
Regards,
Paul
