I use a DAC connected to Pulsar via USB.
Everything has been fine until today when the Pulsar is not connecting to the DAC
the DAC is listed in settings-Audio
I can navigate through my library that is on my NAS.
I've replaced the USB cable and power cycles the DAC and Pulsar
I guess it would be valuable to determine is the DAC USB works
Anyone know if I can connect my IMAC to the DAC and test the USB that way?
I am able to play my TV through the DACS optical connection.
I guess determining if this is a Pulsar problem or a DAC problem would be valuable. I'm just not sure how to do that
Any ideas?
Thank you
Any ideas?
Thank you
