LPSU with PULSEmini
erho
Nov 22, 2024
139
32
Austria
Hello, already got the LPSU for my PulseMini. Connection was clear and easy. Some questions remaining, where is the hot/right phase at the power plug of the LPSU?
Also I read we should leave the streamer powered on, is that the same for the LPSU. If I shut down the LPSU also the Mini is shut down. Is it normal by turning on the LPSU that I have to turn on the Mini manually, I mean it is not turning on automatically by turn on the LPSU??
Thanks
Thanks
anyone please?🙏
The ZENmini and LPSU are frequently stacked together, with the LPSU at the bottom and the ZENmini on top. While positioning them on separate shelves in your Hi-Fi rack may offer improved performance, they still perform perfectly well when stacked. So, there’s no need to worry if you choose the stacked arrangement.
Reactions: erho
😳 But please Dan...
You can't seriously give that advice,.and at the same time aspire to be a "high-end company" with Attention To Detail as its guiding principle.
🔸For example:
Hifi-salesman Björn Wiman at Akkelis Audio in Gothenburg, Sweden.
He had stacked his InnuOs Statement NG.
I told him,."you can't install your Statement streamer like that if you want maximum sound quality."
Björn followed my advice and placed his Statement NG on two separate shelves.
Afterwards he thanked me,.for the better sound quality he got with this placement.
♦️Consensus: Never Stack Devices If You Want to Achieve the Highest Possible Sound Quality From Your Music System.
