FiiO SR11 and Sense DLNA
deerhunt
Sweden
Dear community
I just bought a FiiO SR11 streamer to use it as DLNA output for Sense.
The unit is found and added.
ALAC files is fine, but when playing FLAC file s there is only sound for about 1 sec.
After that the output becomes silent but track looks like continuing to play in Sense.
Any advice or possible setting in Sense that might improve this?
Thanks
Hi deerhunt, all you can do is ensure it is in Compatibility Mode within the Configure Streamer section. But otherwise, best to use the UPnP app that comes suggested by Fiio to pull the music files from AssetUPnP running on the Innuos.
